Author Topic: Rear Axle Bushes  (Read 888 times)
Offline veedubmk2golf
Rear Axle Bushes
« on: 16 August 2012, 01:38 »
mine need replacing and want to do them myself, is there any tools on the market to remove old and fit new ones? thanks in advance
Offline Granta Gti
Re: Rear Axle Bushes
« Reply #1 on: 16 August 2012, 07:41 »
You can get tools to help you put the new bush in but for removing them alloy yourself a couple of hours and get a sharp chisell and hammer. Bit of a pig of a job
Offline jamie1989
« Reply #2 on: 16 August 2012, 08:24 »
A good drill to drill out the rubber, a decent hacksaw to cut a a peice of the alloy cage out of the axle then crush the alloy together and chisel it out.
First time doing it you will take on a drive with basis tools around 3-4hours, second time would take about hour and 1/2.
I would buy polybushes to replace them as they dont need pressing in (I used the ones from PSI tuning, the bush fits in nicely and a metal sleeve crushes the bush in tight)
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline eddie_t
« Reply #3 on: 16 August 2012, 12:37 »
Its not a very friendly job to do on the drive.
« Last Edit: 16 August 2012, 12:39 by eddie_t »
1.8t aum currently FOR SALE!
Offline jamie1989
« Reply #4 on: 16 August 2012, 13:01 »
It is with basic tools.
Depends on the person. Iv changed nearly everything on my car on my drive mate.
Offline mcgee9t2
« Reply #5 on: 16 August 2012, 13:03 »
i agree, get poly bushes there easier to get in, if your just going for standard bushes, a big of threaded bar a few bolts and some plate to push the bush in
