Author Topic: AFR Gauges  (Read 693 times)
Offline Yohan
AFR Gauges
« on: 15 August 2012, 16:03 »
Afternoon,
Just wondered whose running an AFR gauge and what make if they are?
Heard good things about the AEM Wideband 02 UEGO Gauge. http://www.aemelectronics.com/wideband-air-fuel-systems-15/digital-wideband-air-fuel-gauge-25/
The engine it would be going on is a 1.8T AMK (S3).
I already have gauges for Oil Pressure, Oil Temp, Boost, and Voltage, but I've always wondered if I should have AFR as well.
Does it just connect in where my existing lambda probe (already mapped out) goes?
Is it a case of connecting the lambda probe up to the gauge and away you go or is there a separate controller required?
