Author Topic: bora net optic trim, what to do with it  (Read 2592 times)
Offline DubAndDubber
Re: bora net optic trim, what to do with it
« Reply #10 on: 15 August 2012, 20:58 »
Get a fine/very fine sanding block from halfords
Youll be there for hours with a fine sanding block. Use the lowest grit you can. Then go finer up to your desired finish
Mk5 Golf Gti 06'
Offline AD1.8T
« Reply #11 on: 15 August 2012, 21:20 »
If its anything like doing the handles it will be fine ! I wouldnt go attacking it with 80 grit though  :laugh:
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
« Reply #12 on: 15 August 2012, 23:26 »
i have a really tidy drivers switch panel in net optic with 4 window switches if you need it buddy? pm me if ya interest
...Burn Rubber...Not Your Clutch...
Offline SI74
« Reply #13 on: 16 August 2012, 00:48 »
Make sure when sanding down always rub in the same direction. Have seen some people make a real mess of doing it.
what colour do you think is best to spray it all want a oem look?
You don't need to spray it just start with sone sand paper and rub it through to you get to the alloy but always go in the same direction.  If you look at the real r32 trim the sanding marks are always up and down so to speak of.
« Reply #14 on: 16 August 2012, 18:40 »
I did mine with 60 and worked up to 800. It's just to get the coat of plastic off which can be tough. As I found!
Mk5 Golf Gti 06'
Offline luke300586
« Reply #15 on: 16 August 2012, 18:47 »
do you have any pictures of the finished product? did you rib back and forwards in the same direction
