Author Topic: intermittant electric window  (Read 1253 times)
Offline vw_golf_nutter
« on: 15 August 2012, 13:13 »
hi all,
my passenger side electric window in my 1996 cabrio sometimes works and sometimes doesnt. it seems to be decided when i turn the car on whether its going to work or not.
any ideas?
Offline chippychoppy
Re: intermittant electric window
« Reply #1 on: 15 August 2012, 19:48 »
hey i cant really help on the issue as i have the same sorta probs, it just never works on the buttons but will randomly go up or down whenever the ignition is turned on! hopefully someone can help! haha
xx kate
Gavv8
« Reply #2 on: 15 August 2012, 19:52 »
First thing to check would be the switches as they do wear out/get dirty, get some replacements from a scrappy.
Offline dubstar9
  • Back to the Golf scene
« Reply #3 on: 15 August 2012, 21:02 »
I have the same prob and on the third set of switches (blue switches - green lit, black switches - green lit & now black switches - red lit) and the problem is still the same.
On mine I have nothing off the passenger door switch and to get it to work on the drivers i have to press down, then up and then down again to get it to go down, once down it will go up off the drivers with no problem. But if I want it to go down again I have do the same routine!!!
Any ideas??? Has stopped working on total closure too now!!!
Offline trog_nfs
« Reply #4 on: 15 August 2012, 21:04 »
The wiring in the bellows between the car and the door gets a bit brittle over time.
There may be a couple of breakages or maybe a short.
« Reply #5 on: 15 August 2012, 22:28 »
its hard because sometimes it works fine so if i start testing all the wiring and switches it may not show a fault!
when it stops working though i cant open it from my side button or the passenger side so perhaps wiring rather than a switch for me? some days i turn the ignition on and it works fine other days i turn the ignition on and theres no power to the window at all!? hhmmm
Gavv8
« Reply #6 on: 16 August 2012, 05:55 »
Try replacement switches first.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 16 August 2012, 07:21 »
Like Trog mentions, sounds like dodgy wiring to me as is a very common failure point on mk3's.
