Author Topic: why the f**k dosn't my car work?? Help!  (Read 2448 times)
Offline the.little.fox
« on: 03 July 2005, 17:19 »
Hey guys,
I've just up-graded my old gti to a mark 2 1991 gti. It is a fine beast in many ways. However.... It is seriously lumpy when it starts, occasionaly cuts out before its been running for 5mins, backfires a treat when changing down the gears and has no power whatsoever below 2000rpm. It also runs a bit too hot.
I've changed the plugs, leads, dist cap, rotor arm, battery which although needed doing has not helped.
It's got a kent cam. Could this cause the starting problem?
It runs fine when warm, although the starting problem seems to have nothing to do with warm or cold. I turned it off earlier for half hour, then it wouldn't re start.
Please help!
the.little.fox.  xx
kingsmk2
Re: why the f**k dosn't my car work?? Help!
« Reply #1 on: 03 July 2005, 17:26 »
right... u need to firstly check the ignition timing and ensure its about 6btdc at 2250rpm with blue temp sender off.. and then set ur co to about 2% on idle.. the reason the co need to be a little  higher is due to the cam and the increased lumpy idle
if u want more help please feel free to ask... but the symptoms sound to me like its not been set up properly after the cam was installed
« Reply #2 on: 03 July 2005, 17:31 »
Thanks. ye, thought the timing should prob be done next. Do you think this is also the reason why it is running a bit hot?
kingsmk2
« Reply #3 on: 03 July 2005, 17:35 »
yeh i recon its under fuelling and has 2 much advence on the ignition... its a 10min setup where r u based??
« Reply #4 on: 03 July 2005, 17:38 »
Aberystwyth in Wales. Miles from anywhere! Thanks, good to know it dosn't sound serious!
Feel free to come and do it for me if you like though. He he, worth a go!
kingsmk2
« Reply #5 on: 03 July 2005, 17:40 »
i think im a few miles from u!! but if u were closer id gladly help... however good luck and let me know if u get stuck  :smiley:
« Reply #6 on: 03 July 2005, 17:43 »
While you're there, any idea how I can get pics of my car up at the bottom of my posts?
kingsmk2
« Reply #7 on: 03 July 2005, 17:52 »
yeh.. goto your profile... and where it says sig u input the img number form photobucket and then its displayed when u log in
if thats no good pls post again
« Reply #8 on: 03 July 2005, 18:05 »
eh? whats photobucket? sorry. I'm so behind with computer stuff!
kingsmk2
« Reply #9 on: 03 July 2005, 18:08 »
http://photobucket.com
try that and see if it works then upload fromyour pc and post usint the img number illustrated under the picture  :smiley:
