Author Topic: Shoulder clicking and weakness  (Read 2994 times)
Offline Khare
  • The bear that khares
Re: Shoulder clicking and weakness
« Reply #10 on: 15 August 2012, 00:01 »
Well my right collarbone broken pretty badly, and it was in the times when you'd get a sling and a pat on the back. None of the surgery they now do to align the bone and all that. There is a visible lump on the bone where the collarbone obviously healed with one half above the other, making it shorter.
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #11 on: 15 August 2012, 00:10 »
You mean in the times AKA about 8 years ago. Medicine really has come on since I also broke my collar bone  :cry:
If it is real bad perhaps you should see a physio, but at the end of the day the muscles/ligaments will take all of the strain possible until they can no more...Quite possible the worst picture ever
But I hope you get the idea, (Go round until the weights touch at 12 oclock!) this really builds up the shoulders well as I have found (I am a mens small to put that in perspective) and has helped me with issues from playing squash and badminton in the past!
Offline Khare
« Reply #12 on: 15 August 2012, 00:16 »
Last time I broke it was just over 5 years ago, that was the time it broke bad. I've yet to have surgery on anything, when I broke my 5th metacarpal and dislocated my little finger again 5 years ago, all I had was 2 of the biggest female nurses on shift trying to pull it back into place, one pulling on the finger and the other holding me back. Nowadays it seems you get screws, pins and plates for most broken bones. Will try out the exercise you suggested. I do shoulder press at gym, but often cut it short due to pain.
Offline scarr89
« Reply #13 on: 15 August 2012, 00:22 »
From my experience shoulder press, on the machine, is a poor exercise. You want to be working all of the shoulder and shoulder related muscles, of which there are at least 3, I think!!  :undecided: To get well sculpted and strong shoulders try that exercise as well as some shoulder shrugs, maybe 3 sets of 8 or so a a couple of times a week and you should feel youself getting stronger. PS you won't be able to do a heavy weight, start low and build up  :wink: :smiley:
As for the pins/screws I'd probably just go with what ever treat the un hopital gave you, surely they know best! No one needs to be setting of metal detectors unnecessarily, especially during the Olympics!  :lipsrsealed: :grin:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #14 on: 15 August 2012, 07:22 »
Mine wasn't pinned or plated either even though it was broken in two places and blatantly should have been - cvnts!  :angry:
Speaking of metalwork, I had titanium plate put in my left eye socket and cheekbone last year and that's not set any metal detectors off anywhere. Apparently it has to be a certain density or something? :undecided:
Offline mcgee9t2
« Reply #15 on: 15 August 2012, 12:38 »
newer metal detectors are able to determine the difference between surgical grade metal and other, gues its probly something to do with the density yeah. only ever had a metal detector go off on me once since i got it done, had no metal on me and the only thing i could think of was my plate. but they couldnt get it to beep on the hand detector when they put it over me...
Offline R32UK
« Reply #16 on: 15 August 2012, 12:51 »
Its probably the most complex joint in the whole body. I have had shoulder problems, so there is only one suggestion I would give.
Get it seen by someone that speciailses in shoulder injuries. Pay if you have to.... it  will be the best money you ever spend. You will probably only need an inital consultation/examination. You can then take this report to a physio and ask them to follow it up with a call to help decide on exercise that will help you.
It very easy to go to a nhs GP and be give a photocopied sheet.... only in 10years time find out you have fcuked yourself beyond repair. :smiley:
Offline Khare
« Reply #17 on: 15 August 2012, 13:08 »
I've booked an appointment with the GP for next tuesday, for this shoulder pain and also for the trouble I'm having breathing through my nose, some may remember my post a few months ago.
Offline Agreeable Slick
  • Unit
« Reply #18 on: 15 August 2012, 13:51 »
Do these exercises to get the rotator cuff working and built up.
http://www.physioroom.com/experts/asktheexperts/answers/qa_mb_20050225.php
The muscle is the problem, the skeleton is just the frame it hangs off.
Offline justalex81
« Reply #19 on: 15 August 2012, 17:55 »
this.
Also stop using resistance machines in the gym and only use free weights that allow freedom of movement. more reps less weight.
