Golf mk2
which dizzy do i use?
Topic: which dizzy do i use? (Read 1669 times)
ians
GTI forum regular
14 August 2012, 19:10 »
i've got a mk2 golf gti PB engine digifant, I want to put a mk3 8v AGG engine code bottom end with my head, so can i use my mk2's ECU and which dizzy do I use the mk3's or the mk2's?
anything else i should be thinking about? I've gt both engines side by side so nows a good time to make changes
The Mighty Elvi
I'm better than you today.
Re: which dizzy do i use?
14 August 2012, 19:19 »
MK2's
ians
GTI forum regular
14 August 2012, 19:22 »
cool cheers
danny_p
Forum addict
14 August 2012, 23:57 »
not straight fit tho...
2e one works, fits hole without adapter and has 4 windows for ignition iirc
all the VW's have gone bar 1.
ians
GTI forum regular
15 August 2012, 20:36 »
Right can I get one from the scrappy what year golf would one of them dizzys be on? And just to make doubly sure the 2e will be a straight fit?
Thanks
Ian
jmsheahan
19 August 2012, 21:03 »
2E will be a straight fit, usual weapon of choice for 2.0 bottom ends.
Will be on early Mk3 Golfs but unsure on exact years. Got mine from eBay, think it was 'retro-ignition' for around £50. Worked a treat on the conversion.
ians
GTI forum regular
Reply #6 on:
05 September 2012, 16:51 »
Cheers for that bit of useful info. I'll start looking thanks again
GolfRich
Reply #7 on:
05 September 2012, 17:18 »
Guys im still very new to this,
I've seen mention of '2e2' or '2e3' quite a bit, what does it refer to?
Last Edit: 05 September 2012, 20:51 by GolfRich
Golf mk2
