Author Topic: k04-22/023  (Read 1715 times)
Offline shaft69
k04-22/023
« on: 13 August 2012, 23:20 »
What difference between k04-022and 023?? Please.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Prawny
  • R-tech power!!!
Re: k04-22/023
« Reply #1 on: 14 August 2012, 08:29 »
EGT hole on the 023 I believe.
Could be wrong, but early cars didn't have EGT, and later ones did, so I THINK that's the difference.
Offline littco
Re: k04-22/023
« Reply #2 on: 14 August 2012, 12:41 »
Absolutely correct.
Offline rio_gti
Re: k04-22/023
« Reply #3 on: 14 August 2012, 13:42 »
what is this egt hole your speaking of??
Offline littco
Re: k04-22/023
« Reply #4 on: 14 August 2012, 14:21 »
Exhaust Gas Temperature probe.
its part of the protection system in the ECU. Older ECU's had a model version what added fuel when the exhaust gas reached as setpoint, this reduce the exhasut temperatures and protected the turbo, manifolds etc etc.
The -023 has an actual probe for precise temperature readings than a modelled temperature from the Lambda probe. It allows you to run higher egt's before adding fuel becuase of the precise nature .
Its a nice to have but not essential.
Offline rio_gti
Re: k04-22/023
« Reply #5 on: 14 August 2012, 15:55 »
oh right!!!
is it on the cold or hot side??
Offline littco
Re: k04-22/023
« Reply #6 on: 14 August 2012, 16:35 »
Hot... normally triggers protection when egt's reach 900degrees
Offline rio_gti
Re: k04-22/023
« Reply #7 on: 14 August 2012, 17:39 »
nice one :afro:
Offline shaft69
Re: k04-22/023
« Reply #8 on: 14 August 2012, 21:10 »
Spot on boys many thanks.
184 Wallgate, Wigan
WN3 4AL
07966492823.
