Author Topic: 1999 mk4 agu gear shift cable adjustment  (Read 7570 times)
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
« on: 13 August 2012, 20:28 »
can anyone direct me to a link showing how to adjust the gear cables on my 1999 mk4, ive seen the video for 2000 + where theres a 5mm hole on the shifter to lock it off... but mine does not have this... my gear stick is really sloppy and needs adjusting asap... cheers guys
...Burn Rubber...Not Your Clutch...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 1999 mk4 agu gear shift cable adjustment
« Reply #1 on: 13 August 2012, 20:53 »
My 1999 car has the hole  :undecided:
Offline Pauly g
« Reply #2 on: 13 August 2012, 20:54 »
I have a 98 mk4 golf and had the same problem,I adjusted mine by adjusted the nut at the gearbox end that sits just above the two linkage cables.think it's a ten mm nut and you can slide it forward or backwards,mine only needed about 1mm moving forward,took some sloppiness out,but not all of it.you just have to try to move it abit at a time as it throws out your gear selection at the same time.i had to remove the battery only to get at the nut,hope this helps abit
Paul
Offline hainesz
« Reply #3 on: 13 August 2012, 21:05 »
so did my last 1999 thats what threw me out...
Offline hainesz
« Reply #4 on: 13 August 2012, 21:07 »
Paul
do you know if there is a detailed link with pics buddy? dont want to mess the gears completly i want it to be 100% sorted 1st time
Offline Prawny
  • R-tech power!!!
« Reply #5 on: 14 August 2012, 08:32 »
the linkages were changed some time in 99 I believe. Earlier cars have a very sloppy crap shift, and have bolt on ends at the box connection. later cars have press on ends held in with circlips.
The alignment lock and 4mm hole on the lever are on later types, earlier types don't have this and feel utterly crap.
If you have the older type, it's a great upgrade to the later type if you get a shifter, cables, and shift tower to fit to the box.
Offline Chris.
« Reply #6 on: 14 August 2012, 21:27 »
Whats your box code?
Click For Build Thread
Offline hainesz
« Reply #7 on: 14 August 2012, 22:53 »
i think i am just going to upgrade it as you mentioned buddy so much simpler to adjust... cheers for the info buddy
Offline Prawny
  • R-tech power!!!
« Reply #8 on: 15 August 2012, 08:43 »
Good idea!
Let me know if you need the parts, I've got 2 complete assemblies in the garage (shifter, cables, shift tower, the lot)
karls3abo
« Reply #9 on: 15 August 2012, 20:45 »
hi prawny. how much would you be looking for, for a complete assembly?
