Author Topic: Rubber seal Cleaning  (Read 3269 times)
Offline robw09
« on: 13 August 2012, 12:01 »
Hi, another question!
Is there an affective way to clean the rubber window seals of a bit of mold and grime?  The general car wash products i use don't seem to make any difference......
Thanks
Rob
Offline Mr GTD
Re: Rubber seal Cleaning
« Reply #1 on: 13 August 2012, 18:16 »
Wud like to know this too, they end up going a really dull blk :sad:
Offline dubber36
« Reply #2 on: 13 August 2012, 18:34 »
Get the baby wipes out.
Offline Dan J
« Reply #3 on: 13 August 2012, 19:32 »
Apc on a cloth, rub the window rubbers well, re soaking cloth with apc as needed, rinse, inspect once dry and re do if needed.
Offline Guy
« Reply #4 on: 13 August 2012, 20:15 »
have you got a pressure washer?
Offline Mr GTD
« Reply #5 on: 13 August 2012, 20:25 »
Why Guy? I have...
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #6 on: 13 August 2012, 20:58 »
Why Guy? I have...
Are you talking about the outside? As if so you could just blast it with your PWer?  :undecided:
 I have a small amount of build up on the inside which I find hard to clean  :sad:
Offline Guy
« Reply #7 on: 13 August 2012, 21:18 »
Why Guy? I have...
if you have mould and mildew build up the easiest thing to do is to spray it with APC or TFR and agitate with a detail brush and then pressure wash off... should only take a few minutes work
note: don't do this in direct sunlight though as some APC's can dry and mark rubbers
another way of treating window rubbers etc is to use Aerospace 303 http://www.cleanyourcar.co.uk/interior/303-aerospace-protectant/prod_366.html
Offline Dan J
« Reply #8 on: 13 August 2012, 23:25 »
Why Guy? I have...
Also look out for runs down the side of the car whilst doing this with apc and rinse straight away so you don't get any marks.
