Author Topic: MFA Not working  (Read 1138 times)
Offline Ratfink
MFA Not working
« on: 13 August 2012, 11:47 »
Ive had a look through the site and done and few searches. I can find info on how to remove clocks etc and change LEDs and so on, but cant find exactly what im after.
My MFA doesnt work at all, it doesnt display anything.  :sad:
Where do i start guys?
Any help will be much appreciated.
Dan
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: MFA Not working
« Reply #1 on: 13 August 2012, 12:12 »
Could be the LCD Display, or the contacts between it, or the actual control circuit,  to be honest, other than cleaning the contacts and a visual check of soldered joints, theres not much you can do other than replace the dials, its easier on the long run.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline GolfGL
Re: MFA Not working
« Reply #2 on: 13 August 2012, 18:31 »
Ive tried replacing mine with known working unit and its a simple job but the lcd's are fragile so the new one broke on removal. Give it a go as they are cheap on ebay or try and find a unit with the same mileage. I cant find any close as mines on 51k! i would suggest removing one first as not all clocks are the same and part nos are stamped on the back.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline Ratfink
Re: MFA Not working
« Reply #3 on: 13 August 2012, 18:43 »
Thanks for the replies guys.
So, you swapped over the little LCD screen as opposed to whole dial?
Ive had a look on ebay and had a similar prob, mines got 81k on the clock.
