Author Topic: Boost issues 1.8t AUQ engine,please help  (Read 3905 times)
Offline Mrwebster
« on: 13 August 2012, 11:40 »
engine revs up fine, idles ok, when your putting it under load  like you want to overtake someone, it will jerk/buck and hold at 3000rpm, if you let off and back on again a couple of times it will boost up again fine but a bit rough,
this problem is intermittent, someitmes it drives fine then next time it will drive poor.
ive fitted,  4 new top quality plugs
4 oem coil packs genuine ones
new vw n75 valve
all the pipes are ok, i replaced one wich looked a little nasty with a genuine part,
its really anoying now as its unpredictable and unsafe to overtake people.
anyone have any suggestions? or do i keep throwing cash at it lol
Golf GTI turbo (230hp)  mx5 / eunos roadster 120bhp Reliant rialto modified (49hp)
Offline Mrwebster
Re: Boost issues 1.8t AUQ engine,please help
« Reply #1 on: 13 August 2012, 11:42 »
also to add,   had it scanned a couple of times,  No engine light on, no codes,
« Reply #2 on: 13 August 2012, 12:02 »
Well my Octavia vRS had the same fault, it turned out to be the maf had failed yet it never stored a fault code.
If your going to replace it stick with Bosch or genuine.
One more tip is to unplug it and try it, if all ok then you know that is the problem.
Offline Mrwebster
« Reply #3 on: 13 August 2012, 12:11 »
I unplugged it still the same dude
Offline brianpologti
« Reply #4 on: 13 August 2012, 17:06 »
Did you have it scanned by Vag com or a snap on one?
Some aftermarket scans don't show all the faults ,
I guess it will come up with 17705 , might be breather pipes under manifold ,
Offline james2
  • No scammers please.
« Reply #5 on: 13 August 2012, 17:08 »
I would check your dv or the activator thing on the turbo that opens the waste gate.  :undecided:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Mrwebster
« Reply #6 on: 13 August 2012, 17:55 »
Vagcom,  I'll change the diverter and check the actuator tonight
Offline Mrwebster
« Reply #7 on: 13 August 2012, 21:45 »
swapped diverter valve   no change   actuator on turbo is free and not stickeing * burnt myself in process*
  could this be a MAP sensor, problem
Offline dan2252
« Reply #8 on: 13 August 2012, 22:34 »
if you buy a maf dont buy a gsf bosh one as it will last about 8,12 months, genuine everytime!
MK4 golf 1.8 turbo agu :)
Offline Mrwebster
« Reply #9 on: 14 August 2012, 08:49 »
the MAF is fine,  i mentioned the MAP (boost sensor)
