Author Topic: repray - how do i get it shiny?  (Read 3821 times)
Offline DON_GEOVANI
« on: 12 August 2012, 16:29 »
I've recently had to replace a headlight washer jet cover and spray it myself. Ive finished with the paint and iv coated it with loads of layers of lacquer, but i just cant seem to get the shiny finish. Any suggestions? I've put about 5 layers of lacquer on now but it doesn't look shiny at all...
The new part i've resprayed on the left - Original cap sprayed from factory on the right
Offline Hoggy
  • Mk4 GT TDI 150.
Re: repray - how do i get it shiny?
« Reply #1 on: 12 August 2012, 16:43 »
Must be the wrong silver paint?
Offline DubAndDubber
« Reply #2 on: 12 August 2012, 16:53 »
Sand in between coats with a fine wet and dry. Sand final coat of lacquer and polish and you should get a shine!
Mk5 Golf Gti 06'
Offline navmk4gti
« Reply #3 on: 12 August 2012, 17:17 »
that does not look like same silver  :undecided:
Offline Anthony
« Reply #4 on: 12 August 2012, 18:22 »
i would take it to a bodyshop you will never make it look right with areosols, and i cant see it being an expensive paint job
2003 GT Tdi 150
Offline AD1.8T
« Reply #5 on: 12 August 2012, 18:28 »
To me that looks like youve done super light coats go to halfords get some rubbing compound and polish..... buff the life out of it !
Offline JimBR
« Reply #6 on: 12 August 2012, 18:30 »
Silver is the worst colour to try and match   :grin:
Offline Chris.
« Reply #7 on: 12 August 2012, 18:32 »
Flat with 1500 upwards to 2500 and polish it with a polisher.
Click For Build Thread
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #8 on: 12 August 2012, 18:34 »
Did you heat the rattle cans up in some hot water before you sprayed them as the finish is night and day if its not the right temp. As said i would try wet sandiing it back using 2000 - 3000 grit wet and dry then try some cutting compound on them but you may need them done again. Silver is a b!tch to get right though even under normal circumstances.
Offline AD1.8T
« Reply #9 on: 12 August 2012, 19:19 »
Where you based mate if your local to me il sort it for you !
