Author Topic: Can I leave Kurust on without applying the paint?  (Read 1705 times)
Offline Khare
  • The bear that khares
« on: 12 August 2012, 12:37 »
I've got some kurust at home that I plan on using on a few bits of rust I have. There are 2 or 3 bits which are no bigger than 3mm diameter and one which is about 6mm or 7mm long. However I don't plan on sanding/priming/painting those bits until later on in the year. Can I apply kurust now to stop the bits from further rusting and leaving it on until I do the full repair later in a few months time?
Offline salsheikh
Re: Can I leave Kurust on without applying the paint?
« Reply #1 on: 14 August 2012, 13:34 »
i did this and it still rusted. on another panel i sanded it down applied kurust and then primer/paint and it lasted a lot longer before rusting through again  :cry:
Offline Khare
« Reply #2 on: 14 August 2012, 16:46 »
I see. Cheers salsheikh.
