Author Topic: Immobiliser  (Read 3905 times)
Offline ErikGTI
Re: Immobiliser
« Reply #20 on: 09 December 2012, 20:04 »
It does not matter actually that we write it on a forum ...I think it has more benefit to inform eachother about the posibilities than to make a thief more wiser...mind you he still has to search for hidden switches...or plugs in his apparatus only to find out that some clever d€ck has switched plus with minus on the OBD so his tool gets fried....
The expert thief rules out OBD and uses his own clocks with a key  :wink:
I would not advise security glass because if you get involved in an accident the fireman will be given a hard time to smash your window in case of an emergency....do not put your own life at risk just to prevent them from stealing your RNS510 ....
A tracker is pretty useless they jam it on the spot or drive it into a truck and away you go...my lease co has be supplying trackers for years and only two cars were found back.. :wink:
If they really want your car they will succeed since mostly it is all being done as organised crime...you will only be lucky to stop an average burglar....and they are also wandering the streets...but you have to be just one step ahead of those fatherless sons in order to outfox them  :angry:
« Last Edit: 09 December 2012, 20:11 by ErikGTI »
I'LL BEAT YOU TO THE BBC STUDIO........
Offline Snoopy
  • Moderator
  • Geoff.
Re: Immobiliser
« Reply #21 on: 09 December 2012, 21:26 »
My father was a fireman and he said when I had mine fitted on the mk1 many many years ago it was not an issue as they had seen it before. He even came with me when I had a demo of it before I got it fitted.  He said it was not an issue and the procedures they use it would not slow them up any. Intact he said the oposite as it stops the glass causing injury to occupants and holds it in one peace. I too was worried but him and his work mates put my mind at rest about it.
« Last Edit: 09 December 2012, 21:30 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline ErikGTI
Re: Immobiliser
« Reply #22 on: 10 December 2012, 15:31 »
Okay that is very good to hear...in fact I am going to do research myself see if it can be retrofitted.
Sorry to misinform  :wink:
