Author Topic: not idleing when cold?  (Read 1330 times)
Offline rbadger55
« on: 11 August 2012, 21:25 »
hi there i have a mk3 16v gti.
its developed a problem last week which is it wont idle when its cold?but idles when its warm.
any suggestions what it might be would be gratefully received.
cheers
rob
Offline AlexBabes
  • Golf MK3 Anniversary
Re: not idleing when cold?
« Reply #1 on: 18 August 2012, 17:57 »
I may not be right, and I am not an expert or a mechanic but my hold MK3 8v GTI used to have LOADS of idling problems on start up, and when coasting up to junction and coming down the gear (it would just cut out)
After some investigation, and £ pain - I wittled it down originally to (potentially) fuse box issues, coil pack, spark plugs and throttle body manifold...   the garage I was using at the the time did a full service and cleaned out the throttle body manifold which was thick with black gunge - and it cured the problem.
Could be a starting point, the VW boffs on here will know lots more though!  good luck.
ps - Or maybe coolant sensor problem???
« Last Edit: 18 August 2012, 17:59 by AlexBabes »
