Author Topic: HOW TO: remove the door cards on a Mk6 Golf  (Read 88491 times)
Offline The Doc
  • E63s Estate - Vito Sport
« on: 11 August 2012, 21:10 »
Anybody got a clue?
Thanks
Craig
« Last Edit: 12 August 2012, 07:28 by The Doc »
Offline ScottA
Re: How do you remove the rear door cards on a Mk6 Golf?
« Reply #1 on: 11 August 2012, 21:45 »
There's probably a couple torx screws and then just pull f'king hard. I can check elsa on Sunday night / Monday if no one does before then.
Offline mike.
« Reply #2 on: 11 August 2012, 22:22 »
Three door front and five door rear card
Detach decorative trim -1- from door trim using wedge
Remove bolts -1- and -2
Remove bolt -1- on underside
Five door front card
Remove 3 bolts
On Both three and five door cars for front door, release door trim from clips in -specified sequence- using wedges
On rear doors release door trim from clips in -specified sequence- using wedges
–   Pull door trim upwards vertically out of window slot.
–   Now unhook Bowden cable from interior door handle on inside of door trim.
–   Depending on vehicle equipment, disconnect wiring harnesses from door trim
« Last Edit: 11 August 2012, 23:08 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline The Doc
« Reply #3 on: 11 August 2012, 23:08 »
Top marks go to Mike, thanks buddy  :wink:
Offline Rislar
« Reply #4 on: 12 August 2012, 00:15 »
Wow, excellent stuff  :smiley:
Offline Jimble
« Reply #5 on: 12 August 2012, 00:19 »
I've said it before but your a credit to the forum Mike!  :cool:
Offline Ess_Three
« Reply #6 on: 12 August 2012, 00:23 »
Doc, you couldn't make this a sticky in the 'Maintenance + info' section, could you?
This sort of stuff is always useful.
..but gaining motorcycles.
Offline The Doc
« Reply #7 on: 12 August 2012, 07:27 »
Roger that  :wink:
Offline GlennQuagmire
Re: HOW TO: remove the door cards on a Mk6 Golf
« Reply #8 on: 12 August 2012, 12:04 »
mike. Where do you get those fancy pics?
I would kill to get my hands on such good instructions :).
Got MSN also if u need to contact me
Offline Keithuk
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
