Its the pipes that run to the SAI. I assume the pumps been removed, but the solenoid on the engine block is still there as you can see it in the picture. just remove all the pipe work, remove the SAI solenoid off the side of the engine block and blank it off, and if you can and it's not been done already remove the SAI pump of the engine block. You will then either need to get the SAI coded.
