Author Topic: Remap  (Read 2956 times)
Offline bullzeye
Remap
« on: 10 August 2012, 00:34 »
Does anyone know of a good ecu remapping place in the north west, id love to go to r tech but its just too far, i rang carbon chip tuning last week but apparently they dont do  mk4 golfs anymore
also after the remap when the car is driven normaly.. will i see slightly better mpg?( Wife uses it for work and travels 30-40  mile per night  so would be a bonus
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
Offline bullzeye
Re: Remap
« Reply #1 on: 10 August 2012, 00:39 »
also i've had the vr6/g60 clutch conversion and i have also got a forge 007p, is it just the spring i need to change for stage 1?
Offline Dalo Harkin
Re: Remap
« Reply #2 on: 10 August 2012, 06:48 »
yes just the spring, uprated air filter if you dont have one, standard exhaust?
MPG should only decrease if she starts flooring it  :smiley:
Awesome GTI do maps, but I personally wouldnt touch them with a barge pole  :angry:
Offline daz veedub
  • Operation 1.8t bolf
Re: Remap
« Reply #3 on: 10 August 2012, 08:16 »
id also make sure you have a good service before and also uprated creation motorsport boost pipes and tip may help as the standered are prone for leaks as i found out when i went for my map  :wink:
and get yourself to R TECH
Offline Toby
  • Car - less
Re: Remap
« Reply #4 on: 10 August 2012, 11:09 »
No ones as good as nick @ r tech!! Well worth the drive  :cool:
Currently down under
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
Re: Remap
« Reply #5 on: 13 August 2012, 13:35 »
Give me a shout mate.
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Offline The Doc
  • E63s Estate - Vito Sport
Re: Remap
« Reply #6 on: 14 August 2012, 12:03 »
We still do golfs just not 1.8t  :wink:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Remap
« Reply #7 on: 15 August 2012, 21:15 »
I have my only dealer up north west...  I can book you in for the 1.8T R-Tech map session at our NW dealer, but you need to book via us to get the R-Tech maps code and to have the map custom setup on the dyno.  Simon will health check and smoke test your car, then run it on the dyno I will then log in to his PC and run VCDS and log your car during a few power runs, Simon will read your stock map and email me, I will use the Gen11 R-Tech base code which will be loaded to your car and logged, we will alter and tweak the map unique to your car, so if you have a weak actuator we can add duty cycle to make sure we are getting the correct power ans safe.
http://ecotechperformance.co.uk/
Nick
 01455 617233
