Author Topic: SOLID YELLOW OIL LIGHT  (Read 1429 times)
Offline dedi82
« on: 08 August 2012, 21:48 »
as above came on so checked oil it was low so topped up to max.the lights still on any ideas? sensor???
Offline mcgee9t2
Re: SOLID YELLOW OIL LIGHT
« Reply #1 on: 08 August 2012, 21:59 »
Sensor.
pick up pipe blocked.
Offline dedi82
« Reply #2 on: 08 August 2012, 22:06 »
Sensor.
pick up pipe blocked. ok mate is that a serious fault? says oil level in manual but level is defo to the max now.
Offline cullygti
« Reply #3 on: 08 August 2012, 22:07 »
hit the search bar and you will see that its probably the pick up pipe the book says my car will do 500 mpg dont believe everything the book says mate  :wink:
Offline dedi82
« Reply #4 on: 08 August 2012, 22:23 »
yer true av done a search and it says oil level red 4 pressure. cud be a fkd sensor maybe as oils cushty,engine runnin fine
Offline Rhyso
« Reply #5 on: 08 August 2012, 22:26 »
Yellow is sensor
Red is pressure
Sensors arent cheap from memory  :undecided:
Worth whipping off the sump to double check the pickup pipe and replace anyway  :wink:
Offline cullygti
« Reply #6 on: 08 August 2012, 22:27 »
mine was the same mate even had new oil change but aint gonna sort it if the pick up pipe is blocked take off the sump and unblock it for the sake of such a simple task it cost me a new engine and if it needs a new pipe they aint to expensive and could save you a few hundred failing that its that then i would start looking at sensors one on the oil breather filter is a good start as it is easily disturbed  :smiley:
Offline dedi82
« Reply #7 on: 08 August 2012, 22:40 »
yeh will do, wud the pressure drop if the pipe is blocked??
Offline cullygti
« Reply #8 on: 08 August 2012, 22:42 »
mine didnt it just stopped altogether resulting in seized enginge  :cry:
Offline dedi82
« Reply #9 on: 12 August 2012, 09:46 »
yeh sound mate got it boxed off now it woz just the sensor, tenner frm the local scrap heap.
