Author Topic: Door lock removal  (Read 780 times)
Offline Luke1981
Door lock removal
« on: 08 August 2012, 19:28 »
I need to remove the barrrel from the drivers side door lock and get it replaced.
Am I correct in thinking you just remove the rubber bung on the outside edge of the door and unscrew
the retaining bolt and the barrel should just pull out?
thanks
Luke
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline mcgee9t2
Re: Door lock removal
« Reply #1 on: 08 August 2012, 19:35 »
thanks
Luke
pretty much yeah
jockgti
« Reply #2 on: 08 August 2012, 21:41 »
don't unscrew all the way or screw will fall inside door just keep turning while pulling barrel and once barrel is out put screw in a few turns
