Author Topic: MFA functions...  (Read 4697 times)
Blue MK2
MFA functions...
« on: 04 October 2003, 20:51 »
My MFA only shows me the mpg, clock and engine temp
it doesnt show me the mph, oil temp or the other functions
Is this normal or can this be fixed and how?
Offline AdamB
  • The Perfect Storm
Re:MFA functions...
« Reply #1 on: 04 October 2003, 20:56 »
mine did that when the battery was getting flat, I just pulled the fuse and reset it all, worked fine then
I don't own this anymore - I just can't be arsed to change the picture
Blue MK2
Re:MFA functions...
« Reply #2 on: 04 October 2003, 21:24 »
thanx 4 that ill try it when i recharge my battery tomorow morning (sound system drained the thing)
Offline Dizzie
  • Make friends with your fast
Re:MFA functions...
« Reply #3 on: 04 October 2003, 22:02 »
yeah after jump starting mine when my battery was f**ked it would f**k up my MFA sometimes. It sometimes even left me without a clock. Usually disconnecting the battery and reconnecting it after a min would sort it out. Now I've got a new battery everything's perfect again. :)
Offline modulater
Re:MFA functions...
« Reply #4 on: 05 October 2003, 23:58 »
Its the little power spikes when you connect the battery or jump start the car that play havoc with the MFA but you cant help doing it. sometimes disconnecting the battery then quickly putting it back on sorts out the problems.
Blue MK2
Re:MFA functions...
« Reply #5 on: 06 October 2003, 17:34 »
I tried the battery trick but i pulled the fuse out instead and it seems fine apart from the oil temp
Any more clues?
Cheerz
Offline AdamB
  • The Perfect Storm
Re:MFA functions...
« Reply #6 on: 06 October 2003, 17:37 »
The oil temp doesn't kick in till its hit 50 degrees, I did a 20 mile journey the other day without getting a reading!!! go race the ass of it and see what you get ;)
Blue MK2
Re:MFA functions...
« Reply #7 on: 06 October 2003, 17:49 »
sorted!  yeah ill try that
golfvr6
Re:MFA functions...
« Reply #8 on: 07 October 2003, 00:29 »
20 miles and the oil didn't hit 50? i think thats not right!
Offline Dizzie
Re:MFA functions...
« Reply #9 on: 07 October 2003, 00:46 »
mine usually takes about 5 mins to get up to 50?c
