Author Topic: Changing My Suspension Again!  (Read 2130 times)
Offline spetzdude
  • I Bleed Blue!
« on: 08 August 2012, 10:12 »
Hello All,
Hope all is well?
Ive had KW shocks and springs fitted on my mk4 for a few years now, and pretty much ever since they have been fitted i have had horrible creaking from the front.
I thoght it was top mounts, and had them chaged but with no joy.
Even had Regal auotosport take them out to see what the problem is but they could not see anything wrong, and said it looks like its the shocks them selfs.
Anyway i want to change the whole setup, with shocks and springs again or coilovers but havent decided.
I was just woundering when im getting the suspension changed, what other mounts/bushes should i also change while its beeing done??
Thank you for your answers!
« Last Edit: 08 August 2012, 10:48 by spetzdude »
Performance mods: Revo stage 2 map, 5 Peice Hose Kit, TIP, evoloution motorsport air filter, N249 by-pass, Forge spliter valve, lowerd 50mm (KW), Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
Cosmetic mods: Tints,De-wiperd the rear, De-badged front grill, Sharan rear badge, Rear spoiler, 4mo rear valance, 4mo front spliter, arero wipers, stubby areial, DOTZ 18" Alloys, Boost guage, Smoothed Bumbers, ECS N75 Vlalve.
BHP: 231
TRQ: 341.3
Offline jamie1989
Re: Changing My Suspension Again!
« Reply #1 on: 08 August 2012, 10:46 »
Buy some JOMs off DPM performance £150 delivered with 2 years warranty.
Also buy some new top mounts and bearings from VW or TPS as ebay ones arent too great.
I would advise that you put some copper grease on the threads once you have them on the car put thats upto you. Job done for less than £200.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline jamie1989
« Reply #2 on: 08 August 2012, 10:49 »
Looking at your sig and your running a revo stage 2,
I would also makesure you polybush your dogbone mount on rear of the gearbox (very cheap), also check your wishbone bushes, drop links and balljoints while your swapping the struts over to makesure they in good shape.
On the rear theres nout really apart form the rear beam bushes..
Good luck.
Offline AD1.8T
« Reply #3 on: 08 August 2012, 11:02 »
Another person from southampton  :shocked: most people on here are miles away lol ....... On a side note from past experiences dont use regal let them stick to there vauxhalls!
Offline Adam
« Reply #4 on: 08 August 2012, 11:18 »
Change your top mounts and bump stops.
Another one here as well :wink:
Down Hill From Here.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 08 August 2012, 11:43 »
I'm close ish lol
Offline spetzdude
  • I Bleed Blue!
« Reply #6 on: 08 August 2012, 13:31 »
Cheers for the info Jamie!
Yea im not a big fan of there work to tbo.
Im down in the Locks heath area if any of you know that?
What are the bump stops?
BHP: 231
TRQ: 341.3
Offline Adam
« Reply #7 on: 08 August 2012, 18:05 »
Yeah I know the area.
These are bump stops, if you choose to run them. If you have reused the bump stops from the original suspension they could be slightly worn.
Offline spetzdude
  • I Bleed Blue!
« Reply #8 on: 08 August 2012, 21:39 »
So does my car have these fitted as standard?
Would you think they need replacing (80000 miles)?
Where abouts do they go? Not seen them before.
Cheers For the help bud.
BHP: 231
TRQ: 341.3
Offline Ray_Ray280
« Reply #9 on: 09 August 2012, 00:28 »
They looks like some sort of sex toy lol
and i wouldnt bother running them waste of money if you ask me
