Author Topic: 1.8 gti dies on me  (Read 4105 times)
Offline daz veedub
  • Operation 1.8t bolf
Re: 1.8 gti dies on me
« Reply #10 on: 07 August 2012, 21:28 »
i have a brand new ignition amp here with receipt if ya need 1  :smiley: £45 posted
Offline dan2252
« Reply #11 on: 07 August 2012, 21:56 »
when my boost pipe used to pop off it gave a strong smell of petrol :)
MK4 golf 1.8 turbo agu :)
Affmaheed
« Reply #12 on: 07 August 2012, 22:06 »
cheers Daz
i will keep that in mind  :smiley:
i had another look with a torch.does not appear to be any splits or hoses off
and there does seam to be a slight misfire
ignition amp maybe
Offline jamie1989
« Reply #13 on: 07 August 2012, 22:37 »
When on boost an it hesitats or stutters it may be the ignition amp.
Take it off first clean off the face an connections try it again failing that buy Daz's and hes as geniune as it comes !
Top bloke  :cool:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline james2
  • No scammers please.
« Reply #14 on: 07 August 2012, 23:46 »
ignition amp playing up it will miss fire and sound like a retarded scooby. Dv playing up you wont get the hiss noise after letting off the gas you get a chatter/flutter noise. Boost leak from pipes ,look for a oily boost pipe (best look by intercooler).Spark plug gone ,you will be lucky to get out of second gear.  :evil: All these have no fault codes.  :nerd: All happened to my 1999 AGU.  :sick: Timing out you get a fault code.  :smug: but it will be cam shaft sensor as r-tech found when mapping it.  :grin:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline daz veedub
« Reply #15 on: 08 August 2012, 19:33 »
tis true jamie nice 1  :smiley:
got a spare agu maf aswell  :wink:
Affmaheed
« Reply #16 on: 10 August 2012, 17:32 »
i checked all the hoses and nothing  :huh:
borrowed a ignition amp and that solved it,so i i bought a new one from ecp  :smiley:
the car is running better than ever  :smiley: :wink:
next jobs are:- cam belt kit, oil and filter change and replace the rear bushes as they are making one hell of a clunking sound
and not to forget the noisy starter  :wink:
when will it end  :wink:
Offline jamie1989
« Reply #17 on: 10 August 2012, 17:50 »
Never
Offline simon_709
« Reply #18 on: 10 August 2012, 21:36 »
As above check all plugs and hoses etc and just have a good look around everything, and the bottom boost pipes from the inter cooler etc. Could try leaving ur battery disconnected overnight as well to reset the ecu? Anythings worth a try :)
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #19 on: 11 August 2012, 12:09 »
always good having a mate with an AGU, easy to swap bits around lol
