Author Topic: Car wont start sometimes ????  (Read 1298 times)
Offline funk3y
« on: 07 August 2012, 14:18 »
Still have problems with my car starting.  One day it will be fine stopping and starting no problem at all.  Next day It will start then it wont turn over at all If i go back to it and will have to wait 5min or so and It will generally start and the EPC/batt light comes on with no turning over.  Its driving me mad and need it sorted.  I took it to a garage and it started every time for them, and he said he checked starter motor and seemed fine aswell as battery.
What the hell can it be.  Could it be a sensor or something.
Offline Adam
Re: Car wont start sometimes ????
« Reply #1 on: 07 August 2012, 14:52 »
Checked the ground cables?
Down Hill From Here.
Offline richw911
« Reply #2 on: 07 August 2012, 15:15 »
Common for mk4 faulty starter motors to do this but as said check the earths and wiring first.
Offline markymarkg
« Reply #3 on: 12 August 2012, 00:01 »
Crank shaft position sensor dirty or failing???
Only a guess!
Offline richw911
« Reply #4 on: 12 August 2012, 11:51 »
Only a guess!
Maybe but he said the engine wont turn over like the battery is flat.  :undecided:
Offline Anthony
« Reply #5 on: 12 August 2012, 12:24 »
I had this and it was the earth cable from the battery
2003 GT Tdi 150
Offline markymarkg
« Reply #6 on: 20 August 2012, 22:28 »
Only a guess!
Der...forgot about that bit!!
