Author Topic: Brake hoses  (Read 1600 times)
Offline rowlers
  • I'm back - MK7 GTI
Brake hoses
« on: 02 July 2005, 14:51 »
16v just failed MOT today!!!
Needs flexible hoses and track rod ends, so its not too bad!!
Is it worth putting braided hoses rather than standard rubber ones???
If so where do I get them and whats the approx cost??? My local factors don't do braided!!
Cheers folks
<img src="http://i21.photobucket.com/albums/b253/rowlers/CIMG0023.jpg" alt="Image hosted by Photobucket.com">
Offline Lewy
Re: Brake hoses
« Reply #1 on: 02 July 2005, 15:27 »
Euro Car Parts do the braided kits (16v - 6 line kit), and the TRE's. All in all it should set you back about £80. Just remember to spray the old hose fittings with a bit of WD40 before trying to undo them, otherwise they may be a bugger to get off.
PLUS use a proper pipe spanner to remove them, otherwise you'll round them off, then your in the poop.
Lewy
Offline rowlers
Re: Brake hoses
« Reply #2 on: 02 July 2005, 15:46 »
cheers for reply, whats a TRE??
also why the 6 line kit? I've seen other 4 line kits for the 16v???
ta
Offline Lewy
Re: Brake hoses
« Reply #3 on: 02 July 2005, 21:43 »
TRE - Track Rod End, sorry. And you'll need a 6 line kit if your 16v has rear discs (I think I'm right), it's only a couple of quid difference, but you're going to have to change the fluid, so why not change all 6 at the same time.
Offline rowlers
Re: Brake hoses
« Reply #4 on: 03 July 2005, 14:11 »
TRE - Should have guessed!!!
Yeh it has got rear discs, so I'll need the 6 line kit.
Cheers for help.
Veedubgt18v
Re: Brake hoses
« Reply #5 on: 03 July 2005, 17:00 »
and the spanner you need is called a claw foot, trust me this is indespensible when it comes to brakes, think vw ones are 11mm but they come in a combination 10/11mm anyway
Offline Lewy
Re: Brake hoses
« Reply #6 on: 03 July 2005, 18:31 »
Claw foot??? It's actual name is a brake pipe spanner - silly I know but hey :wink:
Veedubgt18v
Re: Brake hoses
« Reply #7 on: 04 July 2005, 14:10 »
i meant crow foot. yeah i know weird name but thats what my local mechanic calls them :huh:
