Author Topic: faulty knock sensor  (Read 2618 times)
Offline Turbotezz
  • New Dubber
faulty knock sensor
« on: 06 August 2012, 21:40 »
Would this show up on diagnostics?? Have a KTS200 at work but need to get round to putting it on. Been suggested as the possible cause to my pinking
Offline itavaltalainen
Re: faulty knock sensor
« Reply #1 on: 06 August 2012, 21:58 »
Knock sensor will show up if completely done for. Mine was gone (plastic casing cracked) but still did not really have any pinging but then again ran my old Golf (2.0 2E) on 25-30% E85 blended in with 95 petrol, so higher than normal octane rating.
If you have a 2.0 8v you can use 054 905 377 A instead of the one you have now, cable is longer other than that pretty much the same - however much cheaper!
Offline Turbotezz
  • New Dubber
« Reply #2 on: 07 August 2012, 08:44 »
thanks for the detailed reply dude!!! which engine is the alternative knock sensor from??
« Reply #3 on: 07 August 2012, 17:32 »
This sensor is used on a variety of VAG cars; I listed them all in my ebay auction (unfortunately its gone already):
http://www.ebay.co.uk/itm/190705199335?ssPageName=STRK:MESOX:IT&_trksid=p3984.m1562.l2649
Offline Turbotezz
  • New Dubber
« Reply #4 on: 07 August 2012, 20:45 »
trying to find it on euro car parts but not sure which one it is! Would it be for a 1997 1.8 mk3 golf?? That one comes in at £24 odd??
« Reply #5 on: 07 August 2012, 21:32 »
1.8 mk3 doesn't have a knock sensor - it is supposed to run on 91 (well 75ps one anyway).
This sensor was used on the following mk3's:
VW GOLF III (1H1) 1.6   07.95 - 08.97   74   101   1595
VW GOLF III Variant (1H5) 1.6   07.94 - 04.99   74   101   1595
VW GOLF III Cabriolet (1E7) 1.6   10.94 - 05.98   74   101   1595
VW GOLF III Cabriolet (1E7) 2.0   07.93 - 05.98   85   115   1984
It also works on the other ones, just the cable is a bit too long (I just made a loop with excess cable and fixed it with cable clips to breather pipe).
If you can wait some time order it from here: http://www.ebay.co.uk/itm/VW-Golf-Jetta-MK2-8v-16v-PL-Corrado-G60-Passat-Scirocco-Knock-Sensor-0261231038-/170752517539?pt=Motors_Car_Truck_Parts_Accessories&hash=item27c1a4a5a3
Comes from Canada but is only £14 total.
« Last Edit: 07 August 2012, 21:34 by itavaltalainen »
Offline Turbotezz
  • New Dubber
« Reply #6 on: 08 August 2012, 20:28 »
Thanks dude, thanks for taking the time to find that!
