Author Topic: Clicking noise when turning ??  (Read 2993 times)
Offline Mk3_phill
« on: 05 August 2012, 14:06 »
hey guys and girls i have a mk3 golf 1.4, recently while driving the car i could hear a clicking/popping noise while turning did abit of reasearch and figured out it was the outer cv joint that had gone so had that replaced but the noise still is there when im turning left any ideas guys ?? thank you
Offline search
Re: Clicking noise when turning ??
« Reply #1 on: 05 August 2012, 15:57 »
a cv joint would be more a banging noise tbh. are you on coilovers? it sounds like top mounts to me.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Mk3_phill
« Reply #2 on: 05 August 2012, 17:57 »
Yes  pal I'm on coilies
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #3 on: 05 August 2012, 18:04 »
Had this problem with my coilies, turned out I had overtightened the nut that holds in the strut top bearing and it began to disintegrate. The nut is only supposed to be 20nm. Its the first nut that goes on, not the one that holds the strut top to the car. Just changed them both and now its spot on. But mind you this issue would make a noise turning in both directions.
Offline Mk3_phill
« Reply #4 on: 05 August 2012, 18:15 »
Nope only happens when turning left mate thats whats making me thing its the passenger side outer cv joint that needs replacing now make a Pi** take lol
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 05 August 2012, 19:04 »
Track rod end ??
« Reply #6 on: 05 August 2012, 20:27 »
Clicking is normally a cv joint in trouble.
Offline Mk3_phill
« Reply #7 on: 06 August 2012, 11:50 »
As I had the outer cv joint changed that sorted ye clicking noise now it's more of a clunking noise cars going in garage Tomoz so fingers crossed nothing to expensive
Offline Willo
« Reply #8 on: 06 August 2012, 13:34 »
Sounds like a cv joint mate  that's what happened on my old mondeo changed outer cv and it wasn't greased properly at the garage took like 80 miles to screw up the new one
Offline Mk3_phill
« Reply #9 on: 06 August 2012, 15:06 »
How would I know if it's greased up right ? Like I said once it had been changed the clicking noise went but now I have a clunking/knocking noise
