Author Topic: coolant leak  (Read 1298 times)
Offline mrsaunders
coolant leak
« on: 05 August 2012, 11:28 »
i have a leak i cant find, its running down the power steering pump coming from the left handside so where could this be coming from?
Offline tweed
Re: coolant leak
« Reply #1 on: 05 August 2012, 12:55 »
Hopefully not out the head
Offline itavaltalainen
Re: coolant leak
« Reply #2 on: 05 August 2012, 14:43 »
If it's running down p/s pump then would suspect water pump or thermostat flange.
Offline mrsaunders
Re: coolant leak
« Reply #3 on: 05 August 2012, 16:12 »
If its this then its goin in the bin and I'll never touch a mk3 again
It's not from the thermostat so I'll check around the pump
