Author Topic: aftermarket vs standard gamma, rcd etc  (Read 3605 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: aftermarket vs standard gamma, rcd etc
« Reply #20 on: 11 August 2012, 21:53 »
wish I'd spent a bit more and got the USB version though  :sad:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #21 on: 11 August 2012, 22:31 »
Alpine FTW!
Offline james2
  • No scammers please.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
« Reply #23 on: 11 August 2012, 22:38 »
i know but do you want a usb stick sticking out of it.  :wink:
Offline Steve_PD
« Reply #24 on: 11 August 2012, 22:41 »
Alpine FTW!
Is that a VW cubby hole? Looks upside down. Vents should be at the top :huh:
Offline james2
« Reply #25 on: 11 August 2012, 22:46 »
Alpine FTW!
no it the right way up ,you put your lose change in the holes.  :evil:
Offline Steve_PD
« Reply #26 on: 11 August 2012, 22:49 »
Good way of saving :grin:
Offline Toby
  • Car - less
« Reply #27 on: 11 August 2012, 22:51 »
I had the same as above!! Still have it but unsure to install in to new car  :lipsrsealed: crackin headunit! Sack the cd's off!!
Currently down under
Offline GTi_James
« Reply #28 on: 12 August 2012, 10:27 »
if your worried about a sticky out USB get one of these then
http://www.play.com/PC/PCs/4-/14366695/Hewlett-Packard-V165-8GB-USB-Flash-Drive/Product.html?searchstring=usb+memory+stick&searchsource=0&searchtype=allproducts&urlrefer=search
last time i checked you'd need a CD library to fill 8GB and is great for those who dont have Ipods or Iphones  :cry:
though i did get a £280 Blackberry Playbook free with my Curve and it hasnt failed me yet and i have that Ichat or whatever they call it for Iphone users and BBM  :smug:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #29 on: 12 August 2012, 21:53 »
Alpine FTW!
Yes, its upsidown as its the only way it would go back in. I like my stereos up as high as possible, as the gear stick would be in the way and your arm hits it when pressing buttons.
No change in there unfortunately, im too poor even for change, hence the dirty jeans  :grin:
« Last Edit: 12 August 2012, 21:55 by s-l-i-x »
