Author Topic: turbo actuator  (Read 5124 times)
Offline dan2252
turbo actuator
« on: 04 August 2012, 17:19 »
hello. right ive got a mk4 1.8t agu with a k03s turbo standard actuator got a few running issues boosts alover place somtimes and its rather jerky through the revs when under full throttle.  should you be able to move the actuator? been told yes and others said no. ive gone asfar as pushing a bigish screw driver against it and it still wont move put some wd40 on it and it moved the slightest bit is this normal?
MK4 golf 1.8 turbo agu :)
Offline jamie1989
Re: turbo actuator
« Reply #1 on: 04 August 2012, 18:59 »
Yes with effort you should be able to move the rod on actuator.
If it pulls quite easy then the spring is too weak.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline dan2252
Re: turbo actuator
« Reply #2 on: 04 August 2012, 23:18 »
hmm thats not good then. ive been at it tonight i can not get it to move ive tried and it still wont move. one bit, put it in gear put abit of load under engine slipped clutch and reved it and it didnt move. should it move by reving it to 4k? thanks in advance danny
Offline dan2252
Re: turbo actuator
« Reply #3 on: 05 August 2012, 10:58 »
left it soaked in wd over night and its still not moving anoyone got any ideas? :)
Offline Chris.
Re: turbo actuator
« Reply #4 on: 05 August 2012, 12:27 »
Remove and free it up or replace.
Click For Build Thread
Offline dan2252
Re: turbo actuator
« Reply #5 on: 05 August 2012, 17:24 »
about 100 quid for a forge one think il just buy one of them to be honest :)
Offline mrapoc
Re: turbo actuator
« Reply #6 on: 05 August 2012, 17:32 »
you might have clogged VNT then if it won't move at all
Offline Chris.
Re: turbo actuator
« Reply #7 on: 05 August 2012, 17:48 »
petrols dont have VNT...
Offline dan2252
Re: turbo actuator
« Reply #8 on: 08 August 2012, 00:18 »
managed to free it. wasnt the actuator its self which is seazied it was the bit that goes into the turbo if that makes sense? ahha :) got it warm lots of wd40 big pry bar hammer and it was free and it drives better than ever! boost is alot faster at climbing and seems to hold longer without the surging through the rev range, gonna buy a forge actuator still in a month just so i know its gonna be perfect then,
Offline jamie1989
Re: turbo actuator
« Reply #9 on: 08 August 2012, 08:21 »
Waste gate was stuck shut?
Woww thats weird, never seen or heard that happen before glad you got it sorted.
