Author Topic: valet pro ph nutral dilution?  (Read 3023 times)
Offline sharki786
  • GOT BOOST??
« on: 04 August 2012, 14:05 »
as above. Iv got a small karcher foam lance and wanted to know how much of ph i put in? The car has loads of tree sap on it so car is very sticky. Al.so i will be using megs wash & wax. Megs hand mit with megs water magnet.
Im not a pro but i will be taking pics
For all you guys
Thanks
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Mr GTD
Re: valet pro ph nutral dilution?
« Reply #1 on: 05 August 2012, 08:57 »
Can't help with dilution bit but I wud suggest getting a better lance, the karcher one is real naf and your be constantly refilling it due to its size and the coverage won't be near as good asTHIS ONE
« Last Edit: 10 August 2012, 20:59 by Mr GTD »
Offline mkviken
« Reply #2 on: 10 August 2012, 17:38 »
i have the 600ml lance and i use valetpro too. i usually 3/4 fill the bottle with SF and the rest warm water and set it to max. goes on fairly thick
Golf GTI 7.5 230 white silver
Offline Tazzy
« Reply #3 on: 11 August 2012, 11:35 »
id say 1/5, in a 1L bottle, i use 200ml of ph to 800ml of hot water
If It Comes Off, Modify It!
Offline technics100
« Reply #4 on: 07 September 2012, 12:44 »
I would normally stick about 200ml in the bottom of a 1l bottle, although I have even just filled the bottle with snowfoam and laid it on thick..
1995 Twilight Voilet Mk3 GTi 16V 5 door
Offline Ginge 35Edition
« Reply #5 on: 07 September 2012, 15:48 »
Totally disagree, the karcher one is fine mate. A the end of day you want the lance to spray foam over ya car and it does it, what more could you want? Ive done both cars today and half filled the once bottle and it covered the car nice and thick. Great product, you'll love it.
MonkeyP
« Reply #6 on: 07 September 2012, 21:53 »
I use 200ml of Valet Pro and 100ml or tfr (surfex HD) and fill the 1L bottle with warm water! this gives me enough for 2.5 coats on the car.
the tfr just helps with all the heavy dirt!
Hope that helps mate
Offline waxamomo
« Reply #7 on: 24 September 2012, 18:42 »
I don't think any Snow Foam (although you could try the new ValetPro Advanced Snow Foam) will remove tree sap, you cn try a couple of hits but I think it's going to need a pre-wash, wash, and then claying to get rid of the sap  :cry:
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 30 September 2012, 20:59 »
tbh im pretty suprised what ph nutral can remove lol. if i leave it on for a few mins then pressure wash it off, it does remove the sap (tiny droplets)
*****MK4 GTI T*****
