Author Topic: Clutch pedal dropped to floor  (Read 2970 times)
Offline johnson6672
« on: 04 August 2012, 13:17 »
Clutch pedal has just dropped to the floor . Return spring has come off and there are some bits of metal snapped.off. what bits do i need i am sure.i have seen posts about this in past. can anyone help.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline tom-gardiner
Re: Clutch pedal dropped to floor
« Reply #1 on: 04 August 2012, 14:02 »
ring your local vw dealer, its a common problem. get the part numbers off them then either order yourself or go to garage. there is a 'How To' guide somewhere but cant find it in my bookmarks. It's easy anough to do just aqward.
The Clio didn't as it's naturally aspirated and French  :sick:  :laugh:
My Project Thread ;)
Offline johnson6672
« Reply #2 on: 04 August 2012, 14:05 »
Cheers i thought it was just the pedal any ideas on cost?
Offline sveed1.8T
« Reply #3 on: 04 August 2012, 14:29 »
IIRC about £30-35? So not too bad! :smiley: Try searching for it, as I had this issue last year, n posted about it. Big tip when you fix this, buy some cable ties!! :wink:
Offline JimBR
« Reply #4 on: 04 August 2012, 15:15 »
Its the pedal and two clips you need a white one and a black one.
There's a few guides as previously said.
Offline johnson6672
« Reply #5 on: 04 August 2012, 17:03 »
Found the guide and stripped old one out but i uave a big long spring aswell that was in the foot well after it went any ideas where that has come frkm i know where tge small fiddley one goes but not this big long thing
Offline richw911
Offline sveed1.8T
« Reply #7 on: 04 August 2012, 17:29 »
Offline JimBR
« Reply #8 on: 04 August 2012, 17:34 »
Spring goes over the top. That link will explain better.
Offline johnson6672
« Reply #9 on: 04 August 2012, 19:10 »
Its not the one from the top its about 10 inchs long with a hook at each end????
