Author Topic: Just swapped the relay arm on gear linkage, do yours now!!!  (Read 1698 times)
Offline twotwofour
Made a huge difference to gear change, took 15 minutes and cost less than £20.
You need a 13mm spanner and a screwdriver. No more gear vagueness and feels like new
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline sierragls
Re: Just swapped the relay arm on gear linkage, do yours now!!!
« Reply #1 on: 04 August 2012, 13:05 »
What part is this? Does it get rid of any play in the gear stick?
Offline twotwofour
« Reply #2 on: 04 August 2012, 13:33 »
http://www.golfgtiforum.co.uk/index.php?topic=227284.0
See above, it's the same as a mk2 linkage. I got a kit off eBay.
If the above link doesn't work see the thread in the mk2 maintenance section.
Offline search
« Reply #3 on: 04 August 2012, 19:28 »
STICKY THIS! seems legit i will be doing this ASAP! my gears are getting harder n harder to go in to second
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline twotwofour
« Reply #4 on: 05 August 2012, 22:33 »
This is one part that could cause gear issues but looking at it, it's the most obvious wear item. You can see it clearly from under the bonnet just beside the downpipe. Get you hand in there and feel if there is much movement before the ball contacts the paddles that operate your gears. Easy to do. Only other bits are the plastic cups on the end of the rods. Easy jobs that make a whole load of difference. If your gears are still hard to find you haven't set it up right or need a new gearbox.
Offline Khare
  • The bear that khares
« Reply #5 on: 05 August 2012, 22:35 »
I had stuck a poly relay on my Mk2 and it had made a huge difference. Well worth doing.
