Author Topic: Going to change my cambelt tommorow  (Read 1619 times)
Offline spudboy6
  • Just like a golf ......
« on: 03 August 2012, 22:37 »
Going to change my 1.8 cam belt tommza and the water pump stay and all belts , I've done loads of cam belts before but always get nervous when doin my own ,
Anyone got any tips good guides on the 1.8 adz engine for the jobs I'm doing , looks like I need the alternator off to get the water pump housing out ?
Thanks guys
Wish me luck :)
Offline itavaltalainen
Re: Going to change my cambelt tommorow
« Reply #1 on: 04 August 2012, 08:59 »
To take water pump off you need to take alternator out - it sits on top of the pump. To do that take both aux belts off then just work your way down the alternator, then take top cam belt cover off, that just unclips.
The go on taking off bottom one, for that you'll need to take the pulley off etc. Personally would just go and get a haynes (I did), cambelt renewal is on page 2a-5 to 2a-9 and very well described for the 1.8 and 2.0 8v engines. Sure worth the 15£...
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 04 August 2012, 10:15 »
Yea its very straight forwards on these engines,  the 1.8/2.0L etc, are some of the easiest belts to do, compared to a lot of modern cars anyway, lol.  You shouldn't have any problems.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline spudboy6
« Reply #3 on: 21 August 2012, 00:30 »
i managed it in the end but had a right mental break down half way . i managed to time it up three teeth out ( must have moved upon tightening ! )
luckily it didnt do any damage it still ran but had no power , had this prob three attempts but got it right in the end
NEVER RUSH a cambelt (:
