Author Topic: Slight Misfire.  (Read 1960 times)
Offline chromepro
Slight Misfire.
« on: 03 August 2012, 21:38 »
After having a vagcom connected to my car i am getting the following readings.
P0300 Random misfire Detected - Any Cylinder
P0303 Cylinder #3 - Misfire Detected
I have changed my Plugs and leads and the above fault codes have came back after being erased. Now the misfire is very very slight, i mean you can just make it out on idle and there is a slight and i mean slight wobble on idle also. Now my question is should i change my coil pack or because the misfire is so slight do you think it might be an injector issue?
Offline mar_k
Re: Slight Misfire.
« Reply #1 on: 03 August 2012, 22:32 »
what engine is it?
Offline chromepro
Re: Slight Misfire.
« Reply #2 on: 03 August 2012, 22:33 »
a 2 slow
Offline mar_k
Re: Slight Misfire.
« Reply #3 on: 03 August 2012, 22:36 »
Same as mine then, Had the same thing, Slight misfire on tick over and occasionaly it would hold back when excellerating,
I replaced the coil pack and its been great since
Offline chromepro
Re: Slight Misfire.
« Reply #4 on: 03 August 2012, 22:40 »
Good stuff, coil pack it is then.
Thanks
Offline big stevie
  • "what doesnt kill me makes me stronger"
Re: Slight Misfire.
« Reply #5 on: 04 August 2012, 13:15 »
i had slight miss on my aum on tickover i mean a little pulse i changed my plugs to the bosch super 4's  ngks in it didnt look that new and job was a good one, i thought start with cheap fix first so glad it wasnt a coil pack and car starts better aswell its on the button. :smiley: :smiley: :smiley:
black 5 door 18t aum engine with 19" lm reps and homemade induction, awesome forge 007p,pressed plates, pillar mounted boost and voltage gauge.
Offline tokemk4gti.t
  • 2001 gti turbo :-)
Re: Slight Misfire.
« Reply #6 on: 04 August 2012, 13:24 »
dont the 2.slows always hold back when accelerating?  :laugh:
Offline chromepro
Re: Slight Misfire.
« Reply #7 on: 04 August 2012, 14:02 »
Yes the 2 slows arent the quickest of the mark i agree but believe me they are a good solid engine and very reliable...... Usually!  lol
Offline mar_k
Re: Slight Misfire.
« Reply #8 on: 04 August 2012, 20:35 »
Yes, They are pig slow. If only I could find some one to buy mine Id get shot of it
Offline chromepro
Re: Slight Misfire.
« Reply #9 on: 07 August 2012, 09:05 »
Ebay ?
