Author Topic: Speedo cable part 2  (Read 1463 times)
Offline Jimmyrallye
  • 20vt goodness
Speedo cable part 2
« on: 03 August 2012, 19:23 »
As stated in my last thread that got locked by Mr slick!! Have tried search but still not seen any pics on were speedo cable is located on the gear box ? Is it a nasty job to take in case you drop anything in the gear box ? Thanks jimmy
Offline Gambit
Re: Speedo cable part 2
« Reply #1 on: 03 August 2012, 20:26 »
It goes in top of box just behind reverse light switch, one bolt removes it, just be careful withdrawing it from box incase you pull the speedo drive of the end of the cable.
Offline Gambit
« Reply #2 on: 03 August 2012, 20:30 »
You see the hole beside the selector, thats where cable goes in
Offline Agreeable Slick
  • Unit
« Reply #3 on: 03 August 2012, 20:46 »
Thread 1: http://www.golfgtiforum.co.uk/index.php?topic=11569.0
Thread 2: http://www.golfgtiforum.co.uk/index.php?topic=11308.0
Google also works well.
You can thank me later, and stop sending snotty PM's now. :smiley:
Offline Jimmyrallye
  • 20vt goodness
« Reply #4 on: 03 August 2012, 20:51 »
Thankyou gambit and Mr slick see that didnt hurt did it ;) so i take it you just feed it back through to you see it pop out the dash ? Once its all connected to the gear box .. Thankyou
