Author Topic: Brock B2's Finally Arrived..... Watcha think?  (Read 6275 times)
Offline ...joe
Re: Brock B2's Finally Arrived..... Watcha think?
« Reply #10 on: 01 July 2005, 15:30 »
well the bloke who's doing mine is near gatwick so not too far away, he's a golf nut so should be able to do what you want as he's worked on loads before. let me know what you think?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Judderi
« Reply #11 on: 01 July 2005, 15:34 »
Heres some before and afters which might help
Offline knobby
« Reply #12 on: 01 July 2005, 15:38 »
Looking at those.. i recon i'll be ok.. They are gonna stick out slightly whatever happens i think.. The top of tyre sits inside the arch.. its only really the wheel rim that sticks out.
Gatwick aint far.. its just getting the car there. wonder how long he would need it for?
knobby
Old VW's never die...they just go faster!
Judderi
« Reply #13 on: 01 July 2005, 15:40 »
Ok. Well i hope they fit. I know my 9" Design 90's only just do!
Offline Horney
« Reply #14 on: 01 July 2005, 15:41 »
Knobby,
You could be in trouble here fella. THe law states that the tread of the tyre must be covered when looked down on from the top. If this is not the case then it won't pass an MOT and will more than likely get you tugged by the Boys in Blue. Looking at the pics it looks like the G60 arches should cover the tread and make you legal. But I think to get those wheels to clear inside the arches to lower it is going to be really hard work as they stick out MILES!
Good luck,
Nick
Offline knobby
« Reply #15 on: 01 July 2005, 15:49 »
This picture gives you a better idea as to how much they stick out. I've been told that the rims are allowed to stick out and inch from the body work, anything more than that and you will be done for it??? From that picture i recon the G60 arches should do the trick. Watcha think?
Offline Mr Blue
« Reply #16 on: 01 July 2005, 15:52 »
the boys in Blue :cool:
gotta use that on my sig :cool:
Dont roll the arches u wuss. cut the f**kkers  :angry: :cool:
im cutting my arches soon so ill take pics of how to do them. if u cut the rears then u need to weld them back as they have two skins
 :smiley:
« Last Edit: 01 July 2005, 18:42 by Baby Blue Mk2 »
Judderi
« Reply #17 on: 01 July 2005, 15:57 »
Its gonna be close! Suck it and see! or just cut the arches then fit the wheels  :grin:
Offline knobby
« Reply #18 on: 01 July 2005, 16:07 »
any ideas how much i will be able to cut from the rear before fitting the skin? i am guessing the lip will be joined.
Knobby!
Offline Mr Blue
« Reply #19 on: 01 July 2005, 18:54 »
knobby how much did u pick the rims up for btw?
they look rude :cool:
if your not going lower then cut the lip,and seal it with underseal. if u want to cut more then cut half an inch up of the metal and u shud be fine and not cut any welds off.
