Author Topic: Broken wires to a mystery object.  (Read 1816 times)
Judderi
« on: 01 July 2005, 14:30 »
Does anybody know what this part is and what affect the broken wire will have?
Offline tobz.
Re: Broken wires to a mystery object.
« Reply #1 on: 01 July 2005, 16:54 »
It's the warm-up regulator, will probably be a bit hesitant/gutless/stall etc etc until the engine is fully warm. Might be a bit more difficult to start from cold also.
You got any pics of your dad's split ?
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #2 on: 02 July 2005, 10:15 »
I'll second that!
Try unplugging it and see if you notice a difference, then connect it back up and see if there is a noticable difference on the cold starts!
Judderi
« Reply #3 on: 04 July 2005, 08:52 »
Thought thats what it was. Ok next question which wires shoulb be connected together? the plug seems to have yellow wires but one is connected to a brown wire and the Yellow/Black one looks as if it should be connected to the red wire, is this right?
Offline Deefadog
« Reply #4 on: 04 July 2005, 09:42 »
I'll take a look tonight!
Ain't got the car in work today
Judderi
« Reply #5 on: 04 July 2005, 10:11 »
Ta
Veedubgt18v
« Reply #6 on: 04 July 2005, 14:11 »
looks like someone has fitted a different plug oin the end at some point cos i swear they are meant to be blue......... :huh:
Offline Deefadog
« Reply #7 on: 04 July 2005, 19:13 »
It's the cold start that's the blue plug :)
The plug is white or brownish white on mine (prob just dirty)
white/red goes to the top
brown goes to the bottom! (i think it's brown anyway could be green, it's hard to tell under artificial lights and a dirty engine)
hope that helps mate!
Judderi
« Reply #8 on: 06 July 2005, 08:52 »
Thanks for that. Will wire it back up and see if it starts ok on petrol. Usually i start on LPG but i have noticed it doesent like to start on petrol on a cold morning. Maybe this is the reason.
Ta for all y help.
Offline Deefadog
« Reply #9 on: 06 July 2005, 21:32 »
Hope it works :)
Did you get a chance to test the wiper wire?
