Author Topic: car stalling  (Read 2504 times)
Offline brett
car stalling
« on: 02 August 2012, 14:02 »
alrite all ,little problem,noticed my car wasn't very responsive so thought i would unplug the maf to see if this would improve the problem and point to the maf possibly being the culprit,butttt when i unplugged it the car will idle briefly then stall.So thought i would take it for a spin down the road and back  but when i let off the throttle to go round a corner the car died ,any ideas .Did try the search but couldnt see anything ,maybe just me as have been on nights .As always all help greatly appreciated ,brett
Offline Luke1981
Re: car stalling
« Reply #1 on: 02 August 2012, 14:04 »
Might be worth checking the breather hoses for splits and blockages!
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline brett
Re: car stalling
« Reply #2 on: 02 August 2012, 14:08 »
cheers mate did have a look and all seemed ok as had to replace both the oil breather hoses last year and the others seemed alrite,but now and again can hear what sounds like a slight whistle possibly from throttle body
Offline brett
Re: car stalling
« Reply #3 on: 02 August 2012, 14:57 »
Goig to take the pipes off and check for blockages next as,tried with maf unplugged again and wouldnt even rev properly ,literally tried to rev at idle and it struggled to rev at all grrr
Offline sharki786
  • GOT BOOST??
Re: car stalling
« Reply #4 on: 02 August 2012, 17:44 »
have you cleaned your throttle body with carb cleaner?
If not give that a shot!
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: car stalling
« Reply #5 on: 02 August 2012, 17:49 »
also if your unpluggin your maf and the car dies out then your muff is working fine lols
*****MK4 GTI T*****
Offline brett
Re: car stalling
« Reply #6 on: 02 August 2012, 18:06 »
ye took off and cleaned tb the other week ,and ye did think that with maf ,but remember unplugging it before ,but was still able to drive it ,had spare leads ,coil ,fuel pump and ecu relay .Just swapped the all over and will see how it goes on way to work tonight,cheers mate
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: car stalling
« Reply #7 on: 02 August 2012, 18:11 »
My maf is knackered and i run with it disconnected just now and it runs great but does cut out at junctions sometimes. Sounds like a vacuum leak you have somewhere.
Offline brett
Re: car stalling
« Reply #8 on: 02 August 2012, 18:16 »
 was thinking that but unsure were to start on that front lol,only thing i can think of is that when i've given it some throttle can sometimes hear like a whistle/whooosh if you know what i mean lol,wasnt sure if it could actually be the throttle body itself ?
Offline Gti_Jamo
Re: car stalling
« Reply #9 on: 02 August 2012, 18:45 »
Maybe try spraying a little bit of carb cleaner round the vac lines and throttle body with the engine running, any change in engine tone can indicate a vacuum leak.
