Author Topic: Battery stuck in Maglite  (Read 3331 times)
Offline Steve_B
« on: 02 August 2012, 10:29 »
hi, i have a mini maglite which now has the aaa battery in it stuck in there due to corrosion. Have tried soaking it in wd40 overnight but to no effect. Does anyone have any tips for removing it before i resort to trying to drill it out?
Offline Mitching
Re: Battery stuck in Maglite
« Reply #1 on: 02 August 2012, 10:35 »
Take the front lamp out and get a screw driver in and try and push it through?
Offline Steve_B
« Reply #2 on: 02 August 2012, 10:59 »
You have to take the battery out before you can remove that part unfortunately
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #3 on: 02 August 2012, 11:02 »
Heat up the outside to expand the case.
Offline Steve_B
« Reply #4 on: 02 August 2012, 11:19 »
Good suggestion. Guess I'll have to be careful of those fumes from heated battery acid though.
Offline Mitching
« Reply #5 on: 02 August 2012, 11:34 »
With mine I can unscrew the lens cap (the whole part you twist to turn on/off/adjust beam).
It come right off, the plastic bit that holds the bulb will either be in the cap or still on the main body of the torch - then it just pulls off.
« Reply #6 on: 02 August 2012, 11:42 »
Is that sarcasm, or didn't you study Chemistry at school?  Probably the latter.  :rolleyes:
But just to put you at ease, here's a video, clearly you'll understand it easier than an analysis of what is actually happening chemically.
 :lipsrsealed:
http://www.youtube.com/watch?v=WerFZyMkAX4
Offline Ant1981
  • Feed me, prod me
« Reply #7 on: 02 August 2012, 11:43 »
Drill into the battery, put a self tapper in and pull out with pliers.
'09 Kawasaki Ninja ZX-6R
Offline Mk1Macca
« Reply #8 on: 02 August 2012, 11:59 »
Have you considered just buying a new mag lite? The mini ones cost bugger all.
Offline Len
« Reply #9 on: 02 August 2012, 12:37 »
This!
www.sas.org.uk
www.the-ace.org.uk
