Author Topic: Whats this for?  (Read 3055 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Whats this for?
« Reply #10 on: 03 August 2012, 16:31 »
It might be the same dash loom with the plug, but terminates at the fuse box,  so you would have to add the front engine room harnes into the fuse box and the rest will be there for you.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline FlashRedThree
  • MK III Flash Red 1.4 SE + MK V DBP 2.0T GTI
Re: Whats this for?
« Reply #11 on: 03 August 2012, 20:13 »
Urghh that sounds tedious....thanks.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Whats this for?
« Reply #12 on: 03 August 2012, 21:46 »
All cars as far as im aware came with the plug fitted in the dash loom but as the headlight levellers were an optional extra the front section of loom wont be there. it'sd very easy to change and can be done in 30mins with no electrical faffing or wire cutting involved. It's a simple plug and play swap over.
Offline madmanmart
Re: Whats this for?
« Reply #13 on: 03 August 2012, 22:27 »
Yep all you need to do is change the slam panel wiring loom for one the headlight adjusters.
The rest of the car is wired for it so its a simple job.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: Whats this for?
« Reply #14 on: 04 August 2012, 20:35 »
Pretty sure the early spec 3's didn't have the red plug on the car loom so if you are pre 95, double check you have the red plug there first before going out and buying the loom, adjusters etc  :cool:
