Author Topic: central clocking knightmare!!!!  (Read 950 times)
Offline bigpoppa81
« on: 29 June 2005, 22:39 »
my central locking has gone recently on my 91 gti, i have to use the key in the drivers lock to open the door instead of using my remote on my alarm,the thing is when turning the key in the drivers lock the passengers side lock wont open and to close it you have to close it from the outside with the key in the lock or from inside by pushing the pin down, but the most annoying thing is when you first get you you can hear the rear hatch pump making a noise and the boot wont open from the outside either then after about 2 mins it will stop making the noise- and still not open, help!!! all this CL lark is driving me mad what do i do?
Offline GTI EDITION (aka LTD)
Re: central clocking knightmare!!!!
« Reply #1 on: 30 June 2005, 01:28 »
Sounds like you have a leak somewhere in the system as the central locking pump should only run for a few seconds .
Have a listen and you should be able to hear the leak when the pump is running :wink:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline hartdub
  • MY VW doesn't leak, it marks its spot!
« Reply #2 on: 06 May 2009, 22:25 »
Guys, My central locking system has failed me, well the drivers door anyway !!!
I can her the pump work for about 2/3 secs, it locks everything else but drivers door. I taken the door card off, and tested the blue bellows and it works!
so id say no vacum is getting to the drivers door !
is it a point to just chase the tubing ? or is it something else ? please please help.... its so so so so so so so so annoying !.
thanks. :wink:
