Author Topic: Changing the aux belts  (Read 1394 times)
Offline spudboy6
  • Just like a golf ......
« on: 01 August 2012, 20:19 »
On my 1.8 adz engine , I have two belts , one on the alternator and one to the power steering pump , but looked on euro and can't work out what belts I need , anyone got any part numbers or links to the correct stuff
1.8 8v non air con but have PAS ,
Thanks
Offline itavaltalainen
Re: Changing the aux belts
« Reply #1 on: 01 August 2012, 20:37 »
You'll need a 6PK894 (or 895) - e.g.  for the alternator and water pump and a v-belt 685mm x 11.5mm for PS pump.
Offline spudboy6
« Reply #2 on: 01 August 2012, 21:32 »
Who's part numbers are they ?
Thanks mate
« Reply #3 on: 01 August 2012, 22:25 »
6PK894 = v-rib belt with 6 peaks, 894 mm long - e.g. from Dayco http://www.camskill.co.uk/m28b0s2592p14476/DAYCO_POLY_RIB_BELTS_PK_BELTS_-_Poly_Rib_Belt_-_6PK894_
685x11.5 = v-belt 11.5mm wide (at widest point), 685mm long - e.g. from Gates http://www.fooparts.com/s115x685La.html
Just buy some from Gates, Dayco or Conti those are best and will last longest.
Offline spudboy6
« Reply #4 on: 01 August 2012, 22:39 »
thankyou mate you are some sort of god ! have found all the right size belts from euro (conti belts 685x11.5 and a 6pk894)
my last question is this the correct waterpump to buy
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_1.8_1996/p/car-parts/car-cooling-parts-and-car-heating/cooling/water-pump-gasket/?201440081&1&fbffdf19610e895192d455bc99ed3df800b8d266&000366
that looks like just the pump which looks ideal or do i need to buy the other pump with the whole housing on ?
« Last Edit: 01 August 2012, 22:52 by spudboy6 »
« Reply #5 on: 01 August 2012, 23:23 »
don't buy half a pump get the whole one! much less messing and it costs the same!
I even got one sitting around here if you need it, was two weeks on my car before I scrapped it! Essentially it's new, got receipt from when i bought the pump and scrapped my Golf (it's the exact one from the ebay link below!)... if you're interested send me a PM.
Otherwise all 1.8 and 2.0 8V engines, as well as 100hp 1.6 and diesels on the mk3 have the same water pump:
http://www.ebay.co.uk/itm/Standard-WATER-PUMP-for-Volkswagen-/300638174772?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf|Plat_Gen%3AMK+III&hash=item45ff6e7e34
Offline spudboy6
« Reply #6 on: 01 August 2012, 23:35 »
thanks for all the info , yea ill let you know if i decide to do the pump ill have yours
thanks again
« Reply #7 on: 01 August 2012, 23:48 »
you're welcome.
