Author Topic: Headlights keep blowing  (Read 2450 times)
Offline 67buggers
« on: 01 August 2012, 09:30 »
Got a headlight issue need ideas...... Last year i had some angel eye type lights with seperate main beam and headlights, one day randomly both headlights blew leaving me just main beam and side lights. I now have vento lights and recently fly eyed and joey'd them but since doing this both headlights stopped working and again i only had main beam and side lights so i brought a pair of night breakers but when fitted they did the same thing and thats where i am now , only got main beam and side lights.... My mot is looming so needs sorting. Not checked anything yet as im a bit confused by it.
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline stainesy
Re: Headlights keep blowing
« Reply #1 on: 01 August 2012, 10:03 »
do you have to remove the reverse C shaped bridge from the relay board to run single chamber headlights like the vento ones? i no you do if you fit single chamber golf headlights due to this happening.
Offline 67buggers
« Reply #2 on: 01 August 2012, 12:26 »
.?? Eh? My car would of had single chamber lights originally as its only a 1.4cl
Offline twotwofour
« Reply #3 on: 01 August 2012, 14:24 »
Sound to me like a bad connection, possibly a wire that has cracked with age and is making contact intermittently
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline 67buggers
« Reply #4 on: 01 August 2012, 14:47 »
That'llbe nice and easy to find then!!
Offline stainesy
« Reply #5 on: 01 August 2012, 16:06 »
ah right didnt no that. thought it was a gti. my bad
Offline twotwofour
« Reply #6 on: 01 August 2012, 16:47 »
Just remove the bulbs, switch on the lights and touch the contacts with the multi meter. Compare volts and resistance. Should be reasonably easy. Get a friend to wiggle the wires. Especially where it goes into the connector block
Offline 67buggers
« Reply #7 on: 01 August 2012, 17:18 »
Friend?! Lol nice obe ill give it ago
Offline 67buggers
« Reply #8 on: 02 August 2012, 00:38 »
Just tried a working switch and that's not it, checked all fuses which are fine, after a bit of messing around the fuse box area I lost my main beam! It now intermittently comes on if I knock the fuse box in the right place which is suggesting bad connection somewhere....unless you guys know better?
Offline itavaltalainen
« Reply #9 on: 02 August 2012, 18:43 »
when you had twin chamber ones, were they both on at the same time? then you got c bridge in there....
also have you measured voltage when the engine is running? could be that you alternator spits out too high a voltage.
