Author Topic: shortshift kits  (Read 2204 times)
Offline richie2480
shortshift kits
« on: 04 October 2003, 18:38 »
I want to buy a short shift kit for my mk2 gti16v. Can anyone recommend one and are these kits easy to fit?
Offline tinman
Re:shortshift kits
« Reply #1 on: 04 October 2003, 19:29 »
eh? is it getting a little tiresome?
the 16v is pretty short as it is...
Tin
Offline richie2480
Re:shortshift kits
« Reply #2 on: 05 October 2003, 11:42 »
well not tyresome but it is getting a bit sloppy i think so i thought a short shift kit might help
Offline Gambit
Re:shortshift kits
« Reply #3 on: 06 October 2003, 09:23 »
shortshift kit & weighed shift rod make gear changes that much sweeter
best ?30 i ever invested for the car!!
shift rod is ?12 from VAG, and i got the shortshift 2nd hand for ?15
Offline Helios_Blue_Valver
Re:shortshift kits
« Reply #4 on: 07 October 2003, 00:55 »
if your shifting is getting sloppy look under the bonnet at where the main shift rod joins into the gear linkage at the transmission. should be a ball shaped bit there called the relay shaft. about 30 quid at VW will get you a new one. piece of p!ss to change and tightens up the shifting alot.
Offline richie2480
Re:shortshift kits
« Reply #5 on: 07 October 2003, 23:27 »
Thanks I'll try that but I still fancy trying a shor tshift kit too.
