Author Topic: painting interior trim  (Read 1927 times)
Offline Khare
  • The bear that khares
« on: 31 July 2012, 10:53 »
I want to spray the interior cream trim in black to match the recovered headlining, should I smooth it down first or just plastic primer then paint?
Offline rolty_gti
Re: painting interior trim
« Reply #1 on: 31 July 2012, 11:12 »
Depends what finish your after, if you want it smooth looking keep applying thin coats of primer until smooth then paint desired colour.
If you want the grainy texture of trim as it is now a coat of primer then top colour then lacquer.
I think this is what you meant?
LCR Decor - Quality affordable home improvements, we also take on commercial work, www.lcr-decor.co.uk free quotes! essex/london/kent and surrounding areas. call lee-07984106950 e-mail-leerolt@lcr-decor.co.uk
Offline Khare
« Reply #2 on: 31 July 2012, 22:49 »
Yup, cheers buddy. Sandind needed before or not?
Offline rolty_gti
« Reply #3 on: 01 August 2012, 12:29 »
No mate just key it up a bit with a sanding pad to etch the surface, wipe down with pre-paint or thinners to get rid of grime/dust.apply primer layer by layer and then top coat and lacquer, use wet and dry between primer and top coats for an ultra smooth finish  :wink:
Offline Khare
« Reply #4 on: 01 August 2012, 18:30 »
Perfect. Thanks  :smiley:
