Author Topic: vr6 maf  (Read 1068 times)
Offline markgti1.8t
vr6 maf
« on: 30 July 2012, 20:53 »
hi there is the vr6 AUTOMATIC maf the same as the vr6 manual maf thanks
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline jamie1989
Re: vr6 maf
« Reply #1 on: 30 July 2012, 20:54 »
I cant see why not....
If you get the part number I will check mine for you.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline markgti1.8t
Re: vr6 maf
« Reply #2 on: 30 July 2012, 20:59 »
found one in a scrappy for £5 so just  bought it
Offline jamie1989
Re: vr6 maf
« Reply #3 on: 30 July 2012, 21:05 »
legend whats the part number mate il check mine for you.
Although are you using this for a 1.8t?
Offline jamie1989
Re: vr6 maf
« Reply #4 on: 30 July 2012, 21:06 »
Actually doesnt matter is it 3inch?
If it is then you got the right one.
You need to remove the sensor with a security torx bit and replace it with a 1.8t one from your existing maf.
Offline DunnDeal12
  • Limited
Re: vr6 maf
« Reply #5 on: 30 July 2012, 21:06 »
make sure its odb2 as well.
Offline jamie1989
Re: vr6 maf
« Reply #6 on: 30 July 2012, 21:12 »
good call
Offline markgti1.8t
Re: vr6 maf
« Reply #7 on: 30 July 2012, 22:41 »
3inch and it is odb2 so looks like a good buy as they are about £50 on eBay wont be able to fit it till i  get the car remapped i go to a lot of scrap yard so if a see any more will stick them on here for what i get them for
Offline jamie1989
Re: vr6 maf
« Reply #8 on: 31 July 2012, 10:41 »
Good man  :cool:
