Author Topic: Fan sender continuity 2 pins ?  (Read 1366 times)
Offline WYATT
« on: 30 July 2012, 13:15 »
Hello , wondering on a fan sender , it has two stage's and two live pins
These figure are example not exact but you get the picture ,
T1 = 95 degrees
T2 = 105 degrees
I have aftermarket twin fan setup on my 20v , would one pin have continuity at a time ?
My thinking is if I took my power from the lower temp one , I could be open for the short rise in temp to then be left with no power there once it gets to the 2nd stage of heat
Maybe bare and join both wires together coming out of the sender to be on safe side ?
Thanks
Offline Santiago
Re: Fan sender continuity 2 pins ?
« Reply #1 on: 30 July 2012, 14:44 »
Pretty sure it goes - as temperature rises - neither live, then T1 live, then both T1 and T2 live.
That's based on a Mk2 golf one anyway.
