Author Topic: Single Head Lamp Conversion  (Read 2588 times)
Offline Organisys
  • Old and Slow...
« on: 29 June 2005, 12:37 »
Quick question, which may be a silly one!
If I buy a single headlamp grille, how do I get the main beam lights to work as part of the larger outer lamps?
How does the wiring and bulbs work?
Ta.
Maybe a silly question coz, I havn't looked at the actual car in detail !
Offline Agreeable Slick
  • Unit
Re: Single Head Lamp Conversion
« Reply #1 on: 29 June 2005, 12:46 »
there is already the wire for full beam incorporated into the single wiring loom. The spots are just a add on. Easy swap.  :smiley:
Judderi
« Reply #2 on: 29 June 2005, 12:48 »
The large lamps already have and do main beam. All you will have to do is unplug and remove the small ones and replace the grill.
  • Unit
« Reply #3 on: 29 June 2005, 12:51 »
spot lamps are already mounted in the grill anyhow  :wink: just a case of unplugging and swapping grills.
Judderi
« Reply #4 on: 29 June 2005, 12:55 »
You lost me mate. How would spot lamps be incorporated into a single headlamp grill? Surely the idea of a single grill is to have a single set of lights?
Offline Organisys
  • Old and Slow...
« Reply #5 on: 29 June 2005, 13:18 »
Ah so, there is a main beam in the outer lamps! now i see. The inner ones are just spots!I will check on my car when it is dark... cheers.
Judderi
« Reply #6 on: 29 June 2005, 13:25 »
Correct. Just dont look directly at them when your testing it  :laugh:
  • Unit
« Reply #7 on: 29 June 2005, 14:45 »
I am presuming he has a twin light grill on atm. In which case the spots are mounted to the grill so they will pop out when he removes said twin light grill.
Then just stick in the single light grill. Job done.
 :smiley:
Judderi
« Reply #8 on: 29 June 2005, 14:51 »
Apologies, i get what your saying now.
  • Unit
« Reply #9 on: 29 June 2005, 15:05 »
yeah i just re-read it i was getting confused too.  :rolleyes:
